UMC
Feb 02, 2021Tutor
Can't connect my Google home mini to Nighthawk C7000v2
Just purchased a Netgear C7000v2 cable modem and can't get it to communicate with my Home Google mini. I've tried resetting modem and the mini home device. I've confirmed that Access Control is ...
- Feb 03, 2021
Thanks for your reply, but I had already tried that and it didn't work either.
Feb 02, 2021Guru - Experienced User
When you installed the C7000, did you use the same ssid/password as the one you had prior? I swap out router/combo devices constantly and when I use the same ssid/password, they've all auto-reconnected. and i have several google mini's.
Not been an issue
