UMC
Feb 02, 2021Tutor
Can't connect my Google home mini to Nighthawk C7000v2
Just purchased a Netgear C7000v2 cable modem and can't get it to communicate with my Home Google mini. I've tried resetting modem and the mini home device. I've confirmed that Access Control is ...
- Feb 03, 2021
Thanks for your reply, but I had already tried that and it didn't work either.
UMC
Feb 02, 2021Tutor
Hi, thanks for your response. I was using a leased modem, so I purchased this one and I'm using the ssid and password associated with this one. I don't remember my old ssid.
Feb 02, 2021Guru - Experienced User
did you try removing the google mini from the "home" setup?
https://support.google.com/googlenest/answer/9691327?hl=en#zippy=%2Cremove-devices-from-a-home
or factory resetting it ?
- UMCFeb 02, 2021Tutor
Yes, I tried both -- removing the google mini from the "home" setup and factory resetting it ? I also work with Google support for 2 days and the last agent I worked with is going to see if they can replace the device.
- michaelkenwardFeb 03, 2021Guru - Experienced User
You might get a few clues here:
Search - NETGEAR Communities – Google home mini
and, for the Solved ones:
- UMCFeb 03, 2021Tutor
