KenBush's avatar
KenBush
Can't connect to http://router login.net
I need to do some admin work on my router but I can't log into http://routerlogin.net
Did this website change?  I'm connected to my home Internet. I need to set up another device and can't log in. Any help is greatly appreciated.   Thanks.
  • Hi David. I had tried this ip addresses previously and that didn't work. I finally rebooted my router and presto the net gear console came up.  Problem solved. Thanks again for you suggestion. Much appreciated.
    Ken.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello KenBush
    try using 192.168.1.1 or 192.168.0.1 in your web browser see if that works.
    DarrenM
    Ken.
