dbyrnes's avatar
dbyrnes
Can't connect to HTTPS sites via wifi
I have a modem/router C3700.  I have not been able to connect to https sites like banks, library, or other secured sites on wifi with new Win10 laptop.  We have 3 other laptops and 2 tablets on the s...
  • dbyrnes's avatar
    dbyrnes
    Aug 31, 2015
    MS Support updated the driver for my Qualcomm Atheros QCA9377 Wireless Adapter which was updated August 25, 2015 specifically for Windows 10, 64 bit.  Problem solved!  Thanks to DarrenM for helping.  Would give you a thumbs up if I could find it.
