dbyrnes
Aug 27, 2015Aspirant
Can't connect to HTTPS sites via wifi
I have a modem/router C3700. I have not been able to connect to https sites like banks, library, or other secured sites on wifi with new Win10 laptop. We have 3 other laptops and 2 tablets on the s...
- Aug 31, 2015
MS Support updated the driver for my Qualcomm Atheros QCA9377 Wireless Adapter which was updated August 25, 2015 specifically for Windows 10, 64 bit. Problem solved! Thanks to DarrenM for helping. Would give you a thumbs up if I could find it.
dbyrnes
Aug 31, 2015Aspirant
Thanks again. I tried that, but it didn't help. Currently, I've been elevated to MS Support tech Level 2. I'm going to pursue the Windows 10 side since every other machine in my house is on this wifi and works fine. I'll let you know what they find, if anything.
dbyrnes
