neTbK
May 11, 2017Follower
Can't connect to Netgear N900 gateway on PC
I use a PC running Windows 8.1, with Kaspersky installed on it (If that matters). I've been trying to login to the gateway for my router, a Netgear N900 CG4500BD. However everytime I try to access it, either Chrome or Netgear comes up with an error message.
When I use my default gateway, 192.168.0.1, to try to access the Netgear settings, Chrome gives an error: ERR_EMPTY_RESPONSE when loading the page. When I use routerlogin.com and routerlogin.net, Netgear's error message says that I need to connect to the router's WiFi network, even though I am.
If anybody could help, that would be great. Thanks in advance.
1 Reply
Kaspersky has been known to block access to the router. Uninstalling it seems to be the only guaranteed way to work. You can reinstall it after you have logged into the router.
