SomebodyInGNV
Mar 19, 2024Guide
Can't connect to Orbi 2.6.9 with OpenVPN 2.6.9
As the subject says, and as others have described, I can't connect to my Orbi CBR40 in Windows 11. The OpenVPN client indicates with an icon that it's connected, but it really isn't. IPConfig/all sho...
- Mar 19, 2024
Just to confirm..... The Windows 11 computer is not connected to the Orbi LAN when using OpenVPN, correct?
All of the VPN files should be in the same folder before they are imported into the OpenVPN client.
CrimpOn
Mar 19, 2024Guru - Experienced User
- SomebodyInGNVMar 19, 2024GuideCorrect. I connect to my phone hotspot and turn off wifi on the phone.
- SomebodyInGNVMar 19, 2024GuideWith respect to the certs being in the same directory as the ovpn file when opened, they are. That's what's puzzling.
- CrimpOnMar 20, 2024Guru - Experienced User
SomebodyInGNV wrote:
With respect to the certs being in the same directory as the ovpn file when opened, they are. That's what's puzzling.Hmmm. This is confusing. My Windows 11 PC has OpenVPN GUI 11.47.0.0/OpenVPN 2.6..9. (I notice that OpenVPN 2.6.10 just came out today and am debating whether to install it or not.)
I am disappointed that my log file shows very little and wondering if using the GUI front end "makes a difference". The GUI does not seem to have a setting for Debug level of the log file.
p.s. Unlike the smartphone versions of OpenVPN, the 'version 2' of OpenVPN supports both
- tun connections, where the connection is a Layer 3 "tunnel", and
- tap connections, where the connection is a Layer 2, i.e. part of the Orbi LAN which means that broadcast packets go both ways across the connection.
Version 3 of OpenVPN dropped the tap connection option.
Does it look like this person's question is similar to yours?
https://forums.openvpn.net/viewtopic.php?t=44122
p.s. I don't know what the commend about "wrong area" means.
