SomebodyInGNV
Mar 19, 2024Guide
Can't connect to Orbi 2.6.9 with OpenVPN 2.6.9
As the subject says, and as others have described, I can't connect to my Orbi CBR40 in Windows 11. The OpenVPN client indicates with an icon that it's connected, but it really isn't. IPConfig/all sho...
- Mar 19, 2024
Just to confirm..... The Windows 11 computer is not connected to the Orbi LAN when using OpenVPN, correct?
All of the VPN files should be in the same folder before they are imported into the OpenVPN client.
SomebodyInGNV
Mar 19, 2024Guide
Also, the Android client works perfectly. I can connect to my SAN from my phone when connected to to mobile network, only.
