SomebodyInGNV
Mar 19, 2024Guide
Can't connect to Orbi 2.6.9 with OpenVPN 2.6.9
As the subject says, and as others have described, I can't connect to my Orbi CBR40 in Windows 11. The OpenVPN client indicates with an icon that it's connected, but it really isn't. IPConfig/all sho...
- Mar 19, 2024
Just to confirm..... The Windows 11 computer is not connected to the Orbi LAN when using OpenVPN, correct?
All of the VPN files should be in the same folder before they are imported into the OpenVPN client.
SomebodyInGNV
Mar 19, 2024Guide
I unintentionally hit the solved button. Can that be reversed? The mobile view of the site is awkward.
CrimpOn
Mar 20, 2024Guru - Experienced User
I cannot find a method to "Unsolve" a post.
Like most large companies, Netgear implements software solutions written by other companies. The community forum appears to be called "Lithium", which may have been purchased in 2019 by Khorus. There are numerous 'features' of the forum software that I find annoying.
