lexamx
Jan 29, 2025Aspirant
Can't connect to the VPN Server Nighthawk AX2700
Hi, I setup VPN server but for some reasons I can't access it ➜ Library nc -zvu my_ddns.ddns.net 12973 Connection to my_ddns.ddns.net port 12973 [udp/*] succeeded! My IP is correctly resolved. I...
Kitsap
Jan 29, 2025Master
What device are you using to try to make connection and where is it connecting to the internet from?
You cannot connect to a VPN server with a device that is connected to the same LAN where the server is running.
The device has to be connecting to the internet at a remote location or via a cell connection.
lexamx
Jan 30, 2025Aspirant
Hello,
I have NETGEAR Nighthawk Wifi Cable Modem Router Cable Gateway DOCSIS 3.1 AX2700.
I tried to connect from my laptop using Tunnelblick from internal wifi and mobile hotspot.
I also tried to connect from my iPhone (cell data) using the OpebVpn Connect app.
