TLSky
Nov 10, 2016Guide
Can't connect to Yahoo mail on one device
I'm connnected to Comcast and cannot access Yahoo Mail on my IPAQ PocketPC (running Windows Mobile 6 Classic OS on Wi-Fi). Other devices on the router can connect fine. I found that by connecting a s...
ElaineM
Nov 11, 2016NETGEAR Employee Retired
TLSky
Nov 11, 2016Guide
Router info:
NETGEAR N600 Wi-Fi DOCSIS 3.0 Cable Modem Router (C3700)
- DarrenMNov 15, 2016Sr. NETGEAR Moderator
Hello TLSky
Have you tried changing the DNS to googles DNS and they try to access yahoo mail?
DarrenM
- TLSkyNov 15, 2016Guide
I setup the router to use a static address, but cannot change the DNS settings because Parental Controls is enabled. Following the info on the Parental Controls community web, I uninstalled the Netgear Genie, but I still cannot remove the Parental Controls. When I click on the Advanced/Parental Controls, it takes me to the OpenDNS web. I factory defaulted the router, but then restored the settings to avoid having to spend hours with Comcast. Any suggestions on how to get past the Parental Controls block?...
Update: I turned off the Parental Controls and set the DNS to Google's site (8.8.8.8 and 8.8.4.4). The router rebooted and I verified the settings, but still cannot connect to www.Yahoo.com from the IPAQ. (I can connect from other routers and from McDonald's free wifi sites.) Still a mystery...
