TLSky
Nov 10, 2016Guide
Can't connect to Yahoo mail on one device
I'm connnected to Comcast and cannot access Yahoo Mail on my IPAQ PocketPC (running Windows Mobile 6 Classic OS on Wi-Fi). Other devices on the router can connect fine. I found that by connecting a s...
TLSky
Nov 11, 2016Guide
Router info:
NETGEAR N600 Wi-Fi DOCSIS 3.0 Cable Modem Router (C3700)
DarrenM
Nov 15, 2016Sr. NETGEAR Moderator
Hello TLSky
Have you tried changing the DNS to googles DNS and they try to access yahoo mail?
DarrenM
- TLSkyNov 15, 2016Guide
I setup the router to use a static address, but cannot change the DNS settings because Parental Controls is enabled. Following the info on the Parental Controls community web, I uninstalled the Netgear Genie, but I still cannot remove the Parental Controls. When I click on the Advanced/Parental Controls, it takes me to the OpenDNS web. I factory defaulted the router, but then restored the settings to avoid having to spend hours with Comcast. Any suggestions on how to get past the Parental Controls block?...
Update: I turned off the Parental Controls and set the DNS to Google's site (8.8.8.8 and 8.8.4.4). The router rebooted and I verified the settings, but still cannot connect to www.Yahoo.com from the IPAQ. (I can connect from other routers and from McDonald's free wifi sites.) Still a mystery...
- DarrenMNov 17, 2016Sr. NETGEAR Moderator
Hello TLsky
Have you tried to go to yahoo.com using the Ip address which is 206.190.36.45
DarrenM
