puppetforever
Nov 30, 2018Initiate
Cant find Nat Filtering
i am trying to set the nat type to open for multiple devices but i cant find the Nat filtering option on the wan setup?
antinode
Nov 30, 2018Guru
> i am trying to set the nat type to open for multiple devices [...]
Which "multiple devices"?
> [...] but i cant find the Nat filtering option on the wan setup?
Perhaps because there is no such option? Visit
http://netgear.com/support , put in your model number, and look for
Documentation. Get the User Manual. Read?
You might get further if you explained the actual problem which you
are trying to solve, rather than asking how to implement some particular
"solution" to it, whatever it might be.
Note that "cant" is a word, different from "can't".
puppetforever
Dec 01, 2018Initiate
It should be obvious that i already checked on the site and Manuel for the solution and wasn't able to find it or else i wouldn't be here posting about it. As for the problem that you are asking for which you say i dint put is basically what i put there isn't a Nat filtering option for the model i have so im wondering if there is a option for it in a different form and as for the devices it doesn't matter what they are.
