Max022692
Dec 04, 2018Tutor
Cant get desktop to connect
Desktop wont connect to internet threw ethernet on the router. Ethier shows unidentified network or internet access it changes back and forth but no internet ether way. Can direct connect to modem an...
Max022692
Dec 05, 2018Tutor
Tried both suggestion cant access router from that computer and the other didnt work.
- Max022692Dec 06, 2018Tutor
I posted the question like you asked and still havent gotten it to work. Used an external to install netgear genie on the computer to try and let it fix the issue still nothin..
Fixing network. Do not carry out other operations.
Fixing adapter:Intel(R) Ethernet Connection (2) I218-V. Please wait...
The adapter is disabled. Trying to enable it. Please wait...
Enable adapter:Intel(R) Ethernet Connection (2) I218-V successful.
DHCP enabled. Waiting for DHCP to complete..
Testing the gateway...
The gateway is valid
Testing DNS...
Gatway is invalid, trying to fix it...
DHCP server does not work.
DNS is invalid.
Cannot fix DNS.
Try 'ipconfig /renew' command.
