randomuser987
Jul 09, 2020Aspirant
Can't Get Gigabit Speeds on Mediacom with Netgear CM 1000v2
Hi,
I have a Netgear CM 1000v2 modem that I just purchased. When it's provisioned with Mediacom's gigabit internet, I'm not able to get full speed. For example, about 20 minutes ago I ran a speed test and got:
Download Mbps 165.42
Upload Mbps 27.93
And now I'm getting:
Download Mbps 129.18
Upload Mbps 38.22
The modem is certified by mediacom to work with their gigabit internet, but it's not working. I've contacted their support many times to trouble shoot it, reprovision it, have someone come to check the signal, unplug every cable, power cord, etc, but they say that everything is working on their end and everything is provisioned correctly and that it's receiving a strong signal.
I rented a medicom model that they supply (Brand: Technicolor, model CGA4234) and if I reprovision to it, I get 700+ Mbps download speed on average and 60-80 Mbps upload. If I then reprovision back to the CM 1000v2, my speeds drop again. Just to be sure, if I reprovision back to the Technicolor modem, speeds go up. If I reprovison back to the netgear CM again, speeds drop.
With the CM 1000v2, sometimes I get in 200mb to 400mb download and 60 upload, but it doesn't get into the 500+ mbps. I'd expect 700+ on average and hitting into 800.
Users experiencing the same issue:
https://community.netgear.com/t5/Cable-Modems-Routers/Netgear-Cm1000-not-compatible-with-Mediacom-1Gig-internet/td-p/1597261
Firmware version: V1.01.03 (this is the latest according to your documentation)
Connection table and event logs are similar to https://community.netgear.com/t5/Cable-Modems-Routers/Netgear-Cm1000-not-compatible-with-Mediacom-1Gig-internet/m-p/1597345/highlight/true#M13783
- randomuser987Aspirant
I forgot to add, I'm wired directly into a netgear gigabit switch and don't use a router. Furthermore, the issue occurs even if I get rid of the switch and go directly into one PC using the ethernet cable.
I have no wisdom on your speed problem, but, ...
> [...] I'm wired directly into a netgear gigabit switch and don't use a
> router. [...]That, most likely, would need to change. Typical residential service
provides a single external IP address, and connecting multiple client
devices to it using a switch will not let them all work.> [...] I rented a medicom model that they supply (Brand: Technicolor,
> model CGA4234) [...]That's not a modem; it's a "gateway" (modem+router). A Netgear
CMxxxx model is only a modem.- randomuser987Aspirant
Thanks!
1. The switch has worked fine for a couple of years now, if not more. I'm not certain, but I think what happens is the switch provides sub IPs.
2. > That's not a modem; it's a "gateway" (modem+router). A Netgear CMxxxx model is only a modem.
Yeah, it does include wifi and looks like telephone ports as well.
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.Test the CM modem with a wired PC directly connected to the modem with out any router or switches.
If you don't see anything near your spec speeds with this configuration after the ISP and cabes are checked, possible the modem could be faulty. Try a different CM modem.
randomuser987 wrote:Hi,
Upload Mbps 27.93
Upload Mbps 38.22
With the CM 1000v2, sometimes I get in 200mb to 400mb download and 60 upload, but it doesn't get into the 500+ mbps. I'd expect 700+ on average and hitting into 800.Users experiencing the same issue:https://community.netgear.com/t5/Cable-Modems-Routers/Netgear-Cm1000-not-compatible-with-Mediacom-1Gig-internet/td-p/1597261
Connection table and event logs are similar to https://community.netgear.com/t5/Cable-Modems-Routers/Netgear-Cm1000-not-compatible-with-Mediacom-1Gig-internet/m-p/1597345/highlight/true#M13783 - randomuser987Aspirant
Is there anyone that works at netgear that can look into this issue? Or should I be requesting support from netgear somewhere else?
Contact NG support or a forum moderator.
No idea why posts were removed.
Why was my reply to FURRYe38 deleted?
This forum is a complete mess.
