randomuser987
Jul 09, 2020Aspirant
Can't Get Gigabit Speeds on Mediacom with Netgear CM 1000v2
Hi, I have a Netgear CM 1000v2 modem that I just purchased. When it's provisioned with Mediacom's gigabit internet, I'm not able to get full speed. For example, about 20 minutes ago I ran a speed ...
randomuser987
Thanks!
1. The switch has worked fine for a couple of years now, if not more. I'm not certain, but I think what happens is the switch provides sub IPs.
2. > That's not a modem; it's a "gateway" (modem+router). A Netgear CMxxxx model is only a modem.
Yeah, it does include wifi and looks like telephone ports as well.
antinode
Jul 09, 2020Guru
> [...] I think what happens is the switch provides sub IPs.
If so, then it's not a "switch". As usual, an actual model number
might be more helpful than a vague/incomplete/inaccurate description.
> [...] the issue occurs even if I get rid of the switch and go
> directly into one PC using the ethernet cable.
That still points to the modem as the cause of the problem,
regardless of what your not-really-a-switch might actually be.
- randomuser987Jul 09, 2020Aspirant
You're being pedantic about a non-issue :smileyhappy:
It says it's a "5-Port Gigabit Eithernet Switch"
> As usual, an actual model number might be more helpful than a vague/incomplete/inaccurate description.
Helpful for what? It doesn't have anything to do with this issue, since it's not a contributing factor to the speed issue. I only mentioned it so I don't get asked if I have a router that could be causing the issue. Since eliminating the switch and directly connecting to the modem still results in a slow speed, the switch isn't the issue. If you're just curious, it's GS605v5- antinodeJul 09, 2020Guru
It's a non-issue until you try to connect multiple devices to a
simple modem (with single-external-IP-address service from your ISP)
using a switch instead of a NAT router.> [...] it's GS605v5
That's a switch. My original remark still stands.
If you have more exotic (block-of-addresses) service from your ISP,
then my "single external IP address" remarks wouldn't apply.> [...] I only mentioned it so [...]
Vague/incomplete/inaccurate details can cause more confusion than
they avoid.- randomuser987Jul 09, 2020Aspirant
I've been using this switch for years without a router without issue (on multiple modems respectively) and all devices connect to the internet fine. Whether my modem is non-simple or my ISP provides a single-external-IP-address, I do not know. All I know is the two modem model numbers I've provided and that if I eliminate the switch, the speed is still slow with the Netgear CM 1000v2, therefore the switch is not the issue nor is a router an issue (since I'm not using a router).
> Vague/incomplete/inaccurate details can cause more confusion than they avoid.
Pedantism even more so :smileytongue:
