DaveWP's avatar
DaveWP
Follower
Aug 25, 2020
Can't get my ethernet connection to work
I have a new C7000 connected to Xfinity which works great in the wireless mode, but when I try to connect it driectly using my ethernet cable it will not work.  I am using a 2019 iMac running Catalin...
  • FURRYe38's avatar
    Aug 25, 2020
    Is the network connecting showing a IP and DNS address when connected?
    Are you using a USB to ethernet adapter?
    Swap LAN cables and LAN ports on the Modem.
    Try a different wired device to check for connection.
    DaveWP wrote:
    I have a new C7000 connected to Xfinity which works great in the wireless mode, but when I try to connect it driectly using my ethernet cable it will not work.  I am using a 2019 iMac running Catalina 10.15.3.  The network shows green  and says connected in System Preferences but nothing works.  Help.
