Cal-to-NH
Dec 25, 2022Initiate
Can't get to dashboard AC1900 Router Model C7000v2
Hi folks. After faithful service for 4 years, I had an awful power surge during a storm. My router came back with the designations from the factory - NETGEAR76-5G and NETGEAR-76 - the 5G and 2.4G c...
Dec 25, 2022Guru - Experienced User
I'd start with factory resetting it. (push and hold reset for 7-15 seconds while powered on).
Then install it through the browser and not the app.
When you start, it'll say something along the lines of "netgear recommends using the app....blahblahblah".
Scroll down and on the bottom it'll say something like "i don't have a smart phone".
Click that and just follow the install guide. Easier and faster IMO.
Cal-to-NH
ry Christmas to you and thanks much for the reply.
I have a house full of guests and I think I'll wait until they leave on Monday to try this. Terrified that this will screw everything up by doing this,but am willing to give it a try in order to get everything back to normal. Thanks kindly again....
- plemansDec 26, 2022Guru - Experienced User
good luck! hope it works well
