corvairbob
Sep 27, 2022Tutor
can't get to my c3700 dashboard
i was messing with trying to get a camera connected to a linksys ac1900 router and it just would not connect. so i tried bridging the linksy ac1900 to the netgear c3700 and now i can't see the netgea...
Sep 27, 2022Guru - Experienced User
If you're running 2 routers in router mode, you're in a double nat.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
