V2philips
Jan 24, 2016Aspirant
Can't get WiFi connected. Router model: WNDR4300
V2philips
- ElaineMJan 26, 2016NETGEAR Employee Retired
Hello V2philips
Are you just having problems with the WiFi?
Do you still have internet access through wired connection?
Make sure that the SSID broadcast on the unit is enabled.
In order to check this setting, you will need to access the admin page of the router.
See the same instructions on this link on how to get into that window.
By the way, do this on a computer that can get online.
