MyrouterisaPOS
Aug 03, 2020Aspirant
Can't get WPS on C3700 router/modem to work
I can't get anything to connect to my C3700-100NAS dual band router via wps. My most recent attempt was the dodocool AC1200 wifi repeater. (But also can't connect any printer or any other devices v...
Aug 04, 2020Guru - Experienced User
The dodocool has a browser based setup that can be done. I'd check its manual again or do a quick search on youtube. I found one with a quick search.
https://www.youtube.com/watch?v=ApVwrYGhFHc
And wps can get coded different between manufacturers. its why most devices have a install wizard built in.
MyrouterisaPOS
Aug 04, 2020Aspirant
Yes, I did try that on three different browsers but couldn't access the setup page. I'm not the only one according to Amazon reviews. At any rate, it doesn't help with the two printers not connecting. The one printer, the Epson, used to connect, but no longer does after I moved. That's why I reset the router, thinking a setting may have changed. I also tried giving a different SSID name to the 2.4Ghz band as I've read that most printers only recognize that band. I then tried to manually choose that ssid on both the HP set up software and my old Epson (enterig it into the printer itself). Still no luck. It's so weird.
