kaitlin4599
Mar 09, 2021Aspirant
cant log in to my router C6300
ok so i bought a netgear modem router combo off ebay seller listed it as new in box seller said they bought the modem but realized it wasnt what they needed for the isp service they had so they tosse...
Mar 10, 2021Guru - Experienced User
Try the factory reset.
kaitlin4599
Mar 10, 2021Aspirant
didnt works still cant log in
- plemansMar 10, 2021Guru - Experienced User
It just gives you a blank page?
What are all the led's on it doing?Are you able to ping the router?
Have you tried a different pc/browser?
- kaitlin4599Mar 10, 2021Aspirant
keds are all lit i can access the internet how do i ping it?
So if the led's are all lit and you're able to use the internet, that implies its not bad.
Try using a different web browser and/or pc to access it.
Try using the 192.168.100.1 address.
ok i was able to ping the router and saw no errors
- plemansMar 10, 2021Guru - Experienced Userdid you try a different pc/browser?
And try accessing it using the 192.168.100.1?
