kaitlin4599
Mar 09, 2021Aspirant
cant log in to my router C6300
ok so i bought a netgear modem router combo off ebay seller listed it as new in box seller said they bought the modem but realized it wasnt what they needed for the isp service they had so they tosse...
Mar 10, 2021Guru - Experienced User
did you try a different pc/browser?
And try accessing it using the 192.168.100.1?
kaitlin4599
Mar 10, 2021Aspirant
yup tried that no dice
- plemansMar 10, 2021Guru - Experienced User
kaitlin4599 wrote:yup tried that no dice
you tried a different pc?
Different browser?
Tried the modem's ip address?
I'm doing my best to help you but getting very short/non descriptive responses back. its tough to help with limited info and feedback.
- kaitlin4599Mar 11, 2021Aspirant
i tried everything you suggested i can ping the router from cmd prompt but different pc different browser still the same issue
- plemansMar 11, 2021Guru - Experienced User
Have you tried using a phone browser?
yes even that fails even my iphone fails
