jschwags
Sep 16, 2022Follower
Can't log in to Nighthawk - AC1750 Model C6300v2
I need help! I can't get it to accept password as the password and I've done a factory reset. Any suggestions would be appreciated. Thanks!
Sep 16, 2022Guru - Experienced User
Wire connect a PC to the modem and factory reset the router using the back push pin button. Hold it in for 10 seconds then let go. Then log in to 192.168.0.1 or 192.168.1.1 using a web browser and walk thru the setup wizard. This time write down all important information for safe keeping later on.
