Handgunz
May 04, 2022Follower
can't log in
I have a c7000v2 and can't log in to the router. I log in to neatgear website where I can't get any farther then the two questions. It won't let me do anything with out the right answers which I don...
May 04, 2022Guru - Experienced User
The default ip address for that router is 192.168.0.1
you can access it using the modem side ip address as well at 192.168.100.1
LIke FURRYe38 says, try the factory reset. then set it up and write down your details so you don't forget them next time.
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
