Carijit
Jun 08, 2020Aspirant
Cant Login Back after C7000v2 reset
Hi, Had to reset my c7000v2; but after the reset, I cant get into the router/modem. The 192.168.0.1 aaddress is not pinging, I connected a cable to my laptop but it was unable to receive any IP; ...
Jun 09, 2020Guru - Experienced User
what are all the lights on it doing?
Try resetting it but unhook the coax from it. unhook coax and push reset for 7-15 seconds while its powered on.
then try going through reset again.
