Konalta
May 04, 2020Follower
Can't login to AC1750 router
I am unable to open my router up online using the Ip address and I can't seem to login via routerlogin.net. I want to go in to change my router settings to bridge as well as Ipv 6. Can someone help me...
May 05, 2020Guru - Experienced User
What address are you using?
you can open a command prompt on your computer.
https://www.digitalcitizen.life/7-ways-launch-command-prompt-windows-7-windows-8
The type ipconfig.
the default gateway will show you what the ip address is for the c6300.
