zixa
Apr 16, 2017Aspirant
can't login to my router!
Hi all, i have been unable to login to my router since a couple weeks after i got it, which was 6 months ago! So i cannot change any settings or anything! (eg. disable my bonjour, change securit...
TheEther
Apr 16, 2017Guru
If you truly forgot the password, then you can reset the router to factory settings. Push and hold in the physical reset button for about 8 to 10 seconds until all of the lights flash on and off. Then proceed to set it up as if it were brand new.
zixa
Apr 17, 2017Aspirant
Hi,
thanks for your answer!
Unfortunately, i tried this and it did not work.
I even had another friend come over and try it again, but still it did nothing!
What can i do, is it a faulty button on my device?
If so, it is past the 30 day warranty period, so there would be no way to return it for a new one?
Thanks!
- DarrenMApr 20, 2017Sr. NETGEAR Moderator
Hello zixa
It still may be under hardware warranty you will have to check by registering the device at our support page.
http://www.netgear.com/support/contact.aspx
DarrenM
- zixaApr 21, 2017Aspirant
Hi,
i just went through all the steps and registered my product..........
But as i suspected, it did no good. :(
Then i had to login, then I tried to submit my support request for replacement, but at long last, only got redirected to phone "support", which they say is only "free" for the first 90 days of purchase!?!?!?
so, since i purchased my router modem on Nov 2, 2016, i can't even ask them for a replacement???
my product obviously came defective. If this is how they choose to operate, they won't stay in business too long...
- VE6CGXApr 20, 2017Master
Are you using wired connection or wireless connection trying to log in. Did you try to pin the router? Run this command and see the result.
'ipconfig /all' Right now is your router dead(not connecting to Internet)?
well i have 3 computers, and login doesn't work on any.
1. MAC OS X, iMac, running El Capitan
ethernet wired
2. MAC OS X, MAcbook air, running Sierra
wireless
3. Acer Aspire laptop, running windows XP
wired, and also tried wireless on it
my router works fine. just can't login to access my account settings.
usage: ipconfig <command> <args>
where <command> is one of waitall, getifaddr, ifcount, getoption, getpacket, getv6packet, set, setverboseis the result of running that command you told me.
So what does it mean?
