Ricamiller
Feb 16, 2020Aspirant
Can't login to router Netgear CMD31T
Hi there, I reset the password on my router and now it will not let me login using the new password or the old password. I reset the router several times to factory defaults but still can't logi...
- Feb 26, 2020
Hi there,
I turned the modem off, unscrewed the coax, turned the modem on, let if fully boot up, pressed and held the reset button, let it fully boot again, tried to login with another computer using admin password and it would not accept it.
So, I tried the MSO trick and was successful. I went into the interface and clicked on "reset factory settings", rebooted and boom - logged in using admin password.
I see now that there is way to update anything which is all I wanted to check in the first place. So I am done.
Thanks for trying to help.
Ric
Ricamiller
Feb 24, 2020Aspirant
This is not a solution. It does not work. I performed the steps exactly as described.
Still wating for something that works!
As of now I am locked out of my own modem and cannot update firmware to ensure security.
Feb 24, 2020Guru - Experienced User
Ricamiller wrote:This is not a solution. It does not work. I performed the steps exactly as described.
A. you can't update firmware on modems. The ISP does it. Not the user.
B. What are the led's doing on it?
C. Is your isp seeing the modem on their end when its hooked up?
D. the default logins are usually login: admin password: password They are case sensitive.
- FURRYe38Feb 24, 2020Guru - Experienced User
Try a different PC or laptop wire connected to the modem to see if you can gain access to its web page.
- RicamillerFeb 26, 2020Aspirant
Hi there,
Ric
- RicamillerFeb 27, 2020Aspirant
Sorry - meant to say:
"I see now that there is NO way to update anything which is all I wanted to check in the first place. So I am done."
