Ricamiller
Feb 16, 2020Aspirant
Can't login to router Netgear CMD31T
Hi there, I reset the password on my router and now it will not let me login using the new password or the old password. I reset the router several times to factory defaults but still can't logi...
- Feb 26, 2020
Hi there,
I turned the modem off, unscrewed the coax, turned the modem on, let if fully boot up, pressed and held the reset button, let it fully boot again, tried to login with another computer using admin password and it would not accept it.
So, I tried the MSO trick and was successful. I went into the interface and clicked on "reset factory settings", rebooted and boom - logged in using admin password.
I see now that there is way to update anything which is all I wanted to check in the first place. So I am done.
Thanks for trying to help.
Ric
Feb 24, 2020Guru - Experienced User
Try a different PC or laptop wire connected to the modem to see if you can gain access to its web page.
Ricamiller
Feb 26, 2020Aspirant
Hi there,
Ric
- RicamillerFeb 27, 2020Aspirant
Sorry - meant to say:
"I see now that there is NO way to update anything which is all I wanted to check in the first place. So I am done."
- FURRYe38Feb 27, 2020Guru - Experienced User
Enjoy. :smileywink:
