petergmauro
Sep 14, 2017Aspirant
Can't login to router remotely
I have a : AC1900 Nighthawk Dual-Band Cable Modem Router I've turned on remote management, and , the display page showes the following: ( both boxes are checked for remote management on that page but, it did not copy with the boxes showing as checked) The menu page does show the addresses for remote management, and I can ping the addresses and get a reply , but, I cannot login |
| Turn Remote Management On (HTTP) |
| Turn Remote Management On (HTTPS) |
| Remote Management Address: |
| http://73.100.215.215:9000, http://[2001:558:6017:14e:6876:9e7e:9b0d:939d]:9000 https://73.100.215.215:8443, https://[2001:558:6017:14e:6876:9e7e:9b0d:939d]:8443 |
1 Reply
- Er, you published your public IP address. Now anyone can try logging into your router. You'll probably want to turn off remote management.
Did you enter the full URL into a browser? And did you try logging in from a device while away from home?
