DocRockk's avatar
DocRockk
Cant Login to Router/Modem after factory reset
I somehow lost my wireless connection on the router early Friday am, been troubleshooting since with no luck! Tried all the info in articles posted here about not accessing the router after a reset. ...
  • DocRockk's avatar
    DocRockk
    Nov 20, 2017
    Thanks for your response. You are correct. After talking to the Rep again, it turns out the cause is my ISP. They claim it's the router, but the router is fine. The tech said she will be calling me back tonight, because the two tech support guys at my ISP were clueless, and she will talk with a supervisor, who she has worked with before, as this is a known issue with my ISP and this router modem.. She said they will have to come to the house to do just what you said...unbridge the modem, but if that is something I can do myself, I will look into it. Thanks for your help.
