kdlp
Mar 31, 2016Aspirant
Can't reset password
Am trying to reset my password and none of the Netgear methods are working. When I try to access the netgar page the username password (admin, password) don't work. When I manually enter my ip addr...
kdlp
I'll give it a try, thx.
kdlp
kdlp
I have a hole and a button just below the USB port. I tried holding the button down for 10 seconds and could see no effect when trying to access the sign-in page. I probed the hole with a pin but couldn't feel any button or switch inside. Is it necessary that I restart (power on/off) the router before or after the reset?
kdlp
- DarrenMApr 01, 2016Sr. NETGEAR Moderator
Kdlp
You should have the modem on and hold that reset button on the back for 10 seconds and then just let the modem reset for 2 or 3 minutes you shouldn't need to power it off.
DarrenM
