ZILLAUU82
Jun 30, 2022Aspirant
Cant see 5g on android box
When I use my cax80 I cannot see 5g. I could use it with my c7100v. The cax80 has Wi-Fi 6 and was wondering if there is a setting I could change for my android box to recognize it. I tried manually en...
Jun 30, 2022Guru - Experienced User
Is Smart Connect enabled?
What FW version are you using on the CAX80.
What Android device model do you have? Is this the only device thats not working?
- ZILLAUU82Jun 30, 2022AspirantIt is the latest fw 2.1.3.7. Android TV Box 2022, RK3318 4GB 128GB Supports 2.4G 5.8G Dual WiFi/Bluetooth 4.1 with Mini Backlit Keyboard 3D 4K HDR Mini Android Box. This is the only device having an issue. But it did show 5g on older modem.
- ZILLAUU82Jun 30, 2022AspirantAlso I enabled and disabled smart connect. But, I think ultimately I will return it and get all fire sticks.
