ZILLAUU82
Jun 30, 2022Aspirant
Cant see 5g on android box
When I use my cax80 I cannot see 5g. I could use it with my c7100v. The cax80 has Wi-Fi 6 and was wondering if there is a setting I could change for my android box to recognize it. I tried manually en...
Jun 30, 2022Guru - Experienced User
Is Smart Connect enabled?
What FW version are you using on the CAX80.
What Android device model do you have? Is this the only device thats not working?
ZILLAUU82
It is the latest fw 2.1.3.7. Android TV Box 2022, RK3318 4GB 128GB Supports 2.4G 5.8G Dual WiFi/Bluetooth 4.1 with Mini Backlit Keyboard 3D 4K HDR Mini Android Box. This is the only device having an issue. But it did show 5g on older modem.
