ZILLAUU82
Jun 30, 2022Aspirant
Cant see 5g on android box
When I use my cax80 I cannot see 5g. I could use it with my c7100v. The cax80 has Wi-Fi 6 and was wondering if there is a setting I could change for my android box to recognize it. I tried manually en...
Jun 30, 2022Guru - Experienced User
Is Smart Connect enabled?
What FW version are you using on the CAX80.
What Android device model do you have? Is this the only device thats not working?
ZILLAUU82
Also I enabled and disabled smart connect. But, I think ultimately I will return it and get all fire sticks.
