SSWaltersII
Feb 05, 2022Tutor
Can't setup ReadyShare USB storage on C7000v2
Model: C7000v2 Firmware: V1.03.03 USB Drive: WD EasyStore 1TB w/ 2 NTFS partitions: 310GB & 620GB Using Edge / Chrome / Firefox - on Windows 11 (Pop-up blocker OFF) The router sees the drive...
michaelkenward
Feb 06, 2022Guru - Experienced User
SSWaltersII wrote:
- USB Drive: WD EasyStore 1TB w/ 2 NTFS partitions: 310GB & 620GB
ReadySHARE does not like partitions.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Cable Modems & Routers
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
