SSWaltersII
Feb 05, 2022Tutor
Can't setup ReadyShare USB storage on C7000v2
Model: C7000v2 Firmware: V1.03.03 USB Drive: WD EasyStore 1TB w/ 2 NTFS partitions: 310GB & 620GB Using Edge / Chrome / Firefox - on Windows 11 (Pop-up blocker OFF) The router sees the drive...
Mar 05, 2022Guru - Experienced User
Any progress on this?
SSWaltersII wrote:
- Model: C7000v2
- Firmware: V1.03.03
- USB Drive: WD EasyStore 1TB w/ 2 NTFS partitions: 310GB & 620GB
- Using Edge / Chrome / Firefox - on Windows 11 (Pop-up blocker OFF)
The router sees the drive and the empty 310GB drive. This is visible in Advanced Setup > USB Settings on the ADVANCED tab. (Pic 01)
But it doesn't appear in ReadySHARE on the BASIC tab (Pic 02) or in USB Storage > Basic Settings (Pic 03) or in USB Storage > Advanced Settings (Pic 04) on the ADVANCED tab.
I am able to access the one partition in Windows File Explorer at \\readyshare\T_Drive.
I have rebooted the router twice so far.
Thanks for your time and any help you can offer.
