Brettmcm
Nov 07, 2021Apprentice
Can't stop CAX30 from blocking Oculus from internet
My CAX30 is blocking my Oculus from connecting to the internet, yet I go to the router, it doesn't show it as blocked. I go to Armor it tells you less than nothing, worthless.
PS I shut it off...
- Nov 11, 2021
Glad you got it working. Please mark your thread as solved so others will know.
Enjoy.
Brettmcm
I’ve unplugged and rebooted, I’ve port forwarded it, I’ve allowed it’s IP address to any website, found it blocked in the genie just showed up after the reboot, tired to edit won’t let me, try to go to access control tab, freezes, or if it does get to it. The oculus is no longer there to unblock, if it is there when I edit it there’s no option to unblock it. If I go into the app it’s always miraculously showing up, try to use the slider to give it access and it just “thinks” for 5 minutes and then says “failed try again” and that’s as close as I’ve gotten. With Armor off or on, doesn’t change a thing.
Can’t manually enter in the MAC address or approve its MAC address, can’t give it a reserved IP address. Can’t can’t can’t can’t … must be what the “C” in CAX stands for can’t do **bleep**
Nov 08, 2021Guru - Experienced User
With out using Access Controls or setting any IP addresses, What happens if you try putting the device IP address into the modems DMZ?
- BrettmcmNov 10, 2021ApprenticeI just kept trying from the browser genie and eventually it accepted it … not sure why or how come there was such a long delay but it’s fixed
- FURRYe38Nov 11, 2021Guru - Experienced User
Enjoy.
