Brettmcm
Nov 07, 2021Apprentice
Can't stop CAX30 from blocking Oculus from internet
My CAX30 is blocking my Oculus from connecting to the internet, yet I go to the router, it doesn't show it as blocked. I go to Armor it tells you less than nothing, worthless.
PS I shut it off...
- Nov 11, 2021
Glad you got it working. Please mark your thread as solved so others will know.
Enjoy.
Nov 08, 2021Guru - Experienced User
With out using Access Controls or setting any IP addresses, What happens if you try putting the device IP address into the modems DMZ?
Brettmcm
Nov 10, 2021Apprentice
I just kept trying from the browser genie and eventually it accepted it … not sure why or how come there was such a long delay but it’s fixed
- FURRYe38Nov 11, 2021Guru - Experienced User
Enjoy.
