Huston1976
May 05, 2017Aspirant
Can't update N600 (C3700 100NAS) firmware nor disable IPv6
I have a N600 WiFi cable modem Router and I cannot update its firmware. I went to advanced-Administration and there isn't an option. The firmware is way outdated but I cannot update it! How can I upd...
StarboardBow
Aug 04, 2017Star
Am unsure whether issue remains unresolved, as original post and comments are somewhat dated, but am sharing my experience that may be of benefit...
Similarly have C3700 unit (originally purchased with OEM firmware V1.01.11) which has been upgraded to current V2.02.08 by Comcast xfinity ISP.
As DarrenM has commented below, Netgear cannot directly upgrade firmware (and does not provide means for customer to upgrade firmware themselves) -- firmware version is controlled entirely by ISP.
That said, for Comcast xfinity ISP, contacting their general technical support line is generally useless, as likely you will be connected to offshore call center whose operators have little to no technical expertise and simply regurgitating call script. Instead, directly contact Comcast Tier 2/3 Advanced Repair Dept in Denver, CO (higher level support that call centers eventually escalate to) -- their direct phone number is: 800-718-7419
True, as has been commented on other related posts, Comcast xfinity ISP cannot manually "force" firmware updates, as firmware updates are automatically controlled by their system infrastructure. Instead, what they can do, specifically have them re-provision your cable modem, which as part of provisioning process of identifying and connecting hardware credentials to your account, it will determine your modem's firmware version and download update if necessary.
Note, as indicated above, as of date, V2.02.08 is current firmware version, however, currently have open Netgear Support ticket (see post: https://community.netgear.com/t5/Cable-Modems-Routers/embedded-web-interface-fails-after-week-runtime/m-p/1329401#M9437) in which Netgear has identified firmware flaw in that current version as root-cause of failing embedded web interface known issue, and is supposed to release firmware fix sometime.
MiamiLoco
Oct 16, 2017Aspirant
Thank you VERY much for the information. I did what you said and now I currently have the latest firmware V2.02.16
- RobKatOct 18, 2017Initiate
What did you do exactly to update it?
I have C3700 100NAS as well and my ISP is Spectrum - firmware version is V2.02.08
I'm worried about the Krack WPA2 and they dont seem to care about
- StarboardBowOct 18, 2017Star
RobKat --
Am not familiar with Spectrum ISP, but according to Netgear Support's webpage listing current firmware versions for various modems and ISPs, including C3700 and Spectrum ISP (https://kb.netgear.com/000036375/What-s-the-latest-firmware-version-of-my-NETGEAR-cable-modem-or-modem-router) as of the webpage's 11-Oct-2017 last update date, your stated unit's V2.02.08 appears to already be the current approved version for Spectrum ISP -- the aforementioned V2.02.16 appears to be deployed only for Comcast ISP.
- RobKatOct 19, 2017Initiate
StartboardBow
Thanks for your reply, but the firmware that Spectrum allows us to have doesn't imply that is safe for our router, or that our router is immune from Krack WPA2 issue. It's old and it's overwhelming not to have the possibility to choose the firmware we should have, the day Netgear will come out with the fix, if that they will ever come for older router like ours.:mansad:
