Huston1976
May 05, 2017Aspirant
Can't update N600 (C3700 100NAS) firmware nor disable IPv6
I have a N600 WiFi cable modem Router and I cannot update its firmware. I went to advanced-Administration and there isn't an option. The firmware is way outdated but I cannot update it! How can I upd...
MiamiLoco
Oct 16, 2017Aspirant
Thank you VERY much for the information. I did what you said and now I currently have the latest firmware V2.02.16
RobKat
Oct 18, 2017Initiate
What did you do exactly to update it?
I have C3700 100NAS as well and my ISP is Spectrum - firmware version is V2.02.08
I'm worried about the Krack WPA2 and they dont seem to care about
- StarboardBowOct 18, 2017Star
RobKat --
Am not familiar with Spectrum ISP, but according to Netgear Support's webpage listing current firmware versions for various modems and ISPs, including C3700 and Spectrum ISP (https://kb.netgear.com/000036375/What-s-the-latest-firmware-version-of-my-NETGEAR-cable-modem-or-modem-router) as of the webpage's 11-Oct-2017 last update date, your stated unit's V2.02.08 appears to already be the current approved version for Spectrum ISP -- the aforementioned V2.02.16 appears to be deployed only for Comcast ISP.
- RobKatOct 19, 2017Initiate
StartboardBow
Thanks for your reply, but the firmware that Spectrum allows us to have doesn't imply that is safe for our router, or that our router is immune from Krack WPA2 issue. It's old and it's overwhelming not to have the possibility to choose the firmware we should have, the day Netgear will come out with the fix, if that they will ever come for older router like ours.:mansad:
