MortR's avatar
MortR
Can't Update New Firmware
Running Windows 10 Pro, Netgear Firmware v.2.01.18, Hardware v.3.0 .  The email instructions state to select ADVANCED > Administration, click the Firmware Update or Router Update button, click the Check button, and follow the prompts.  Under ADVANCED > Administration, there are no Firmware Update or Router Update buttons.
  • > [...] there are no Firmware Update or Router Update buttons.
       Cable TV ISPs generally want to control the firmware on cable modems
    which are connected to their networks, so you may not be able to update
    the firmware on your cable (TV) modem.  The ISP can do it.
    > [...] The email instructions [...]
       Did this message mention your modem+router model?
    • MortR's avatar
      MortR
      This is the email I received. Thanks for your answer.  I'll contact my cable company.
      Netgear_email-19
      NETGEAR BUSINESS
       Firmware Update
      Security Fixes Available
      WHY YOU ARE RECEIVING THIS EMAIL:
      NETGEAR values the security of your network and data, so we released new firmware for your WiFi router to address security issues.
      To update your router's firmware, using a computer that is connected to your router's network, log in to your router at http://routerlogin.net, select ADVANCED > Administration, click the Firmware Update or Router Update button, click the Check button, and follow the prompts.
      To read detailed instructions or watch a video demonstrating the steps, visit How do I update my NETGEAR router's firmware using the Check button in the router's web interface?
      For more information about the security issues that we fixed, visit our security advisory page and enter your model number in the Security Advisory Search box, then press Enter.
      What We Are Doing:
      NETGEAR's mission is to be the innovative leader in connecting the world to the internet. To achieve this mission, we strive to earn and maintain your trust by delivering products that are secure and by protecting the privacy and security of your data. NETGEAR is constantly on the lookout for both known and unknown threats. Being pro-active rather than re-active to emerging security issues is fundamental for product support at NETGEAR.
      If you have a security-related support concern, you can contact NETGEAR customer support at [email protected].
      Your security is important to us. Thank you for being a NETGEAR customer.
    • MortR's avatar
      MortR
      Netgear_email-19
      NETGEAR BUSINESS
       Firmware Update
      What We Are Doing:
