nrmccurt
Apr 15, 2018Follower
Can't upgrade firmware on c6300
I'm a Cox customer and my firmware version is 2.0.14. We are receiving DOS attacks and I wanted to upgrade my router to the newest version. When I go to the Cox website, it says the newest version ...
concerned_user
May 30, 2018Tutor
Hello,
I'm also a Cox customer and I contacted both Netgear and Cox technical support (via a conference call). I wasn't able to make any headway with this issue. Netgear said they couldn't provide the update (which I don't understand since they make the product) and Cox refused to push the firmware update because they did not want to be responsible if the modem became unresponsive. This is a gaping security issue with the C6300 Gateway and Netgear needs to provide a way for users to update this product.
- DarrenMMay 31, 2018Sr. NETGEAR Moderator
If your firmware is outdated, you cannot manually upgrade your cable modem’s or modem router’s firmware. You must contact your Internet service provider (ISP) to upgrade your firmware.
DarrenM
