rbjeary
Jan 27, 2020Follower
Capability of receiving Xfinity 100mbb
Re mod C7000v2 Multiple Xfinity speed tests have reflected 30 - 40mbbs on the above Netgear 70 modem. Although I am charged and paying $40/mo.for 100 mbbs, Xfinity tells me that they are transmit...
Jan 28, 2020Guru - Experienced User
Show them this:
http://www.downloads.netgear.com/files/GDC/datasheet/en/C7000.pdf
"24x8 Channel Bonding technology
enables up to 960 Mbps‡
download speeds"
Have the ISP check the signal and line quality UP to the modem.
Be sure there are not coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
