yjiang
Mar 04, 2022Aspirant
Capped to 100 Mbps on Wi-Fi
Xfinity 600 Mbps. Confirmed with cable connection to PC and Macbook Air M1. Netgear C7000. But Wi-Fi on both 2.4 GHz (600 Mbps) and 5 GHz (1.3 Gbps) can only give around 100 Mbps (80-150 Mbps...
Mar 05, 2022Guru - Experienced User
Have you tested other devices and not just the M1?
Have you simply tried a factory reset and reinstall?
yjiang
Mar 05, 2022Aspirant
Reset tried.
iPhone 13 Pro Max Tried.
Still not over 200 Mbps
- michaelkenwardMar 05, 2022Guru - Experienced User
yjiang wrote:
Reset tried.
That looks low for thatphone.
For comparison, what speeds does this device achieve on different wifi sources?
- plemansMar 06, 2022Guru - Experienced User
have you tried any non-iphone/mac devices?
