1artist
Jun 11, 2022Follower
CasaOS Pi Hole docker Configuration on C7000v2 Router Modem
I own a Netgear C7000v2 and connected to it is a Raspberry Pi 4b 8GB PC running CasaOS and Pi Hole as a docker. Here is the configuration problem I am experiencing.
To allow Pi Hole docker to block ads at a network wide level I need it to take over DHCP Server duties. So this requires I disable the DHCP server in the Netgear Genie app (see RED circled text in JPG below).
However, when I disable it and hit "APPLY" the router displays the message below:
"Please change your computer IP address manually if LAN IP subnet will be changed"
When I hit the OK button for the message shown above the result is I lose all internet connection. The only option I have left after this happens is to perform a Factory Reset operation on the router.
My question is, how do I disable the Netgear Genie DHCP Server parameter without losing internet access? I have performed a total of 5 factory resets on my router. So I hope somebody in this community can help me so I can stop performing Factory Resets on my router. 🙂
My goal is to setup Pi Hole at a local area network so that all devices are automatically protected against unwanted ads and tracking. Any assistance will be greatly appreciated. Thank you for your time.
No RepliesBe the first to reply
