satvik
Oct 08, 2020Aspirant
Case #: 43414671 Escalate case
Hi I called the support and I am not being helped at all on this matter, you guys keep repeating the same things about getting the 6 months phone support when clearly the device is faulty. This is u...
schumaku
Oct 08, 2020Guru - Experienced User
Probably not related on threse low WiFi effective data rate numbers, however, the C3700 and the C3700v2 specs state:
- N600 Dual Band WiFi—300+300 Mbps
- Cable Internet speeds up to 340 Mbps
If you got the full wire speed as part of your cable contract (down 340Mb/s or more) - this is above the effective possible capacity of a N300 connection on either 2.4 and on 5 GHz. Some 200 Mb/s should be possible over wireless around the router. This is certainly less than what you can get over the LAN ports. But not as low as what you state.
Or can these be probably MB/s on the speed test? 27MBytes/s x8 would make some 216 Mbit/s - and that would be about right.
- satvikOct 08, 2020Aspirant
Correct I had a N600 beforeI got this. But this router is suffering at speeds like 20-30 mbps itself, My lan gets 40+ on average however wifi gets 10-15mbps. And 25 ft away from the router it goes down to 0.5 - 10mbps range (Mostly on the lower side) I belive the issue is with the router component.
- danchoOct 23, 2020Initiate
Same thing here. My router never has worked (blinks orange power and 1,2,3,4 white). It is defective. It does not broadcast a signal, I cannot see the network name in the list of wifi networks. Therefore I cannot update firmware or run any software tests.
I opened a case well within the 90 days, got a response immediately asking questions. I replied to the email instead of uploading my replies to the website. The router is not in my home, so I see it only rarely due to COVID. Today, I decided to take up the case again. It is closed. It was closed October 7. Phone support ended Oct 20. Today is Oct 23.
The CSR I am speaking to tells me that I have to open a new case, so I did. Then she tells me that I have to pay to talk to somebody above her. This is absurd.
