SimonSaba
Apr 25, 2023Guide
CAX 30 and Time Machine BAckup
I have a CAX 30 Modem/Router with a USB Drive connected formatted with MacOS Extended GUID Partition Scheme. The drive is visible when I mount it using smb://readyshare or smb://routerlogin.net, I do...
- Apr 26, 2023
I don't think the KB article shows the CAX30 as having it discontinued as it was never included in time machine and didn't have it. If you look at the applies to devices for using it, none of the AX routers had time machine built in.
That's why it doesn't show and why only the older devices show it as having been removed.
Apr 26, 2023Guru - Experienced User
You posted this in the ReadyNAS forum area instead of the forum area for cable modems/gateways. Hopefully someone will move it for you.
- plemansApr 26, 2023Guru - Experienced User
