BrickedandLost
May 09, 2023Aspirant
CAX 30 bricked by update
It appears my CAX30 is truly bricked? Arrived from vacation to find no internet.
I've tried to reset it waiting for the lights to start flashing. After reset, the status is:
Power light on
Lightning flashing
Port lights off
2.5 and 5 Ghz lights on...
No ssid is being transmitted; unable to connect manually entering ssid and password.
Using ethernet cable in ports 1-4 results in no lights and no connection.
I couldn't see a way to roll back the firmware update using the USB port.
Emailed netgear; crickets......
Any help on where I've gone wrong (having bought the CAX30 is already on the list), or new methods to try are greatly appreciated.
I would make contact with a forum moderator:
- BrickedandLostAspirant
I'll give it a try
Thanks!
